Would like to set 'Log Window' default to 'Never'
  • Would like to set 'Log Window' default to 'Never'
    Is is possible to set the 'Log Window' to 'Never' by default? I spend a huge amount of time turning it off. It's alway popping up and obscuring things. No doubt it's useful, but for the day-to-day work it more annoying than anything else.
    V-Ray 6.20.06, 3ds Max (3D Studio thru Max 2025), GIGABYTE X570 AORUS Master Motherboard, Ryzen 9 3950x CPU, Noctua NH-D15S CPU Cooler, 128 GB G.SKILL Trident Z Neo DDR4 Ram, NVidia RTX 4090, Space Pilot Pro, Windows 11, Tri-Monitor, Cintiq 13HD
    Autodesk Expert Elite Member
    Ive done it with my render presets, which is also set up in my standard max file. The only time I get it back is if I need to reset vray
      You can create a startup script with this code:
      renderers.current.system_vrayLog_show=0
