Plugin dialog box: how to remove plugin.
  • Plugin dialog box: how to remove plugin.
    When opening a file in Viz 4 (has only been opened on Viz4) a dialog box comes up with:
    Missing DLLS : FileName: boolcntrl.dlc Class: Boolean Controller
    Is there a way to remove this? Im not sure what object it is referencing, my assumption was well a boolean object.
    Any help?
    Thanks.
    Arkitec
    you just have to reinstall the boolcntrl.dlc in your max plugins folder.
      is that a default driver? I dont have any special drivers for boolean stuff, just the viz default....
      Arkitec
        I have noticed since this thing pops up in the last three days. Since then, when I create a panorama out of Viz 4 it crashes. Now, with that said, the panorama renders fine, its on export to quicktime that it crashes.
        PLEASE, any help.
        I am about to try using the panoscript posted.
        Thanks,
        Arkitec
          Well,
          I just "repaired" the installation of viz, hoping it would add the boolcntrl.dlc back into the stdplugins folder and no dice.....I also thought my file is crashing cuz i realized I upgraded to the newest quicktime 6.5.1.
          Still no dice, panorama crashes. I am able to export as a cylindrical, or spherical image but as soon as i export to a quicktime, viz comes back with an error......
          Im totally frustrated as you can see....three post in an hour........
          Arkitec
