BACKBURNER AND DR working together
  • BACKBURNER AND DR working together
    Hey Guys, I have a question about rendering a few jobs that I queued up with Backburner.
    So the question is, when using the network rendering process why doesn't the network render job take advantage of the VRAY DR nodes that I have up and running to get this done quicker?
    I am using VRAY 3.40.02 and MAX 2016
    this seemed to have worked in the past if I am not mistake
    what am I missing here?
    thanks for all your help and knowledge
    Did you enable DR when you sent the job and is the Spawner running on the slaves?
    Kind Regards,
    Morne
      yes and yes
      so you are saying this should work?
        yes it should work
        Is DR working if you dont use BB?
        Kind Regards,
        Morne
          oh yes
          works great when rendering locally and using like 5 to 6 nodes
          but when I send a job to backburner with DR checked the other nodes do not join in
            so nobody else is having trouble with this
            I am the only one?
            also, the answer is that it should work?
              Do you have 'save servers in scene' checked within the DR settings?
              Brendan Coyle | www.brendancoyle.com
                no it is not checked
                should it be?
                  yes, that'll make sure that the other computer uses the same dr config that your local machine is using.
                    If the slaves doesn't join even if "save servers in the scene" option is active you have to manually log on the machine where BB server is started and make those configs.
