Rendering lens effect + disabling memory frame buffer
  • Rendering lens effect + disabling memory frame buffer
    I need to disable the memory frame buffer while rendering a very large image, but when I do the render crashes with the error "lens effect cannot be used without a memory frame buffer". This makes sense... but is there a way to get the bloom and glare effect without going through the VFB window?
    Also I guess I should say I get this crash through backburner as I'm not rendering this locally on my computer.
      Disable V-Fray Frame Buffer completely:
      Enable Lens Effect from Effects Tab, disable Max Frame buffer as well and export the image from the Common Tab:
      With this setup you will be able to render without any frame buffer and the Lens Effects will be correctly applied on the file.
        Does this method still apply? I only seem to be getting the Max lens effects, not the Vray ones....
