I'm a bit confused in regards to the save function with Caustics which the documentation doesn't clarify. Will I need to compute an entirely new caustics map if I change the resolution of render? What kind of impact will it have if I computed the caustics at 1600x1600 and then re-rendered at 3200x3200 but using the previous generated caustics file? What other settings if I modify will require me to re-render the caustics map excluding what is on caustics options of course?
Additionally, if I set the mode to From File it greys out the option Auto save and Switch to saved map become greyed out, I don't understand why it does that. Can I get more simplified explanation what that indicates?
Thanks.
Thanks.
