Ambient Occlusion question
  • Ambient Occlusion question
    So why do my window frames wig out on the AO pass when I'm using the same texture as the beams?
Name:	Screen Shot 2016-09-16 at 8.45.21 PM.png
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    Flipped normal I guess
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
      Silly question, but how do you check for that?
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        Just select these faces in editpoly/mesh and check if the red color bright then it is okay if it is dark click flip to make it bright.if you are not sure just select them and choose flip and do test render.
        Edit normal modifier can also show the normal iirc.
        Xview tool can show you flipped faces in green too:
        https://knowledge.autodesk.com/suppo...B20F2-htm.html
          Shouldn't the "Double Sided" checkbox in the AO texture fix it, too?
          Software:
          Windows 7 Ultimate x64 SP1
          3ds Max 2016 SP4
          V-Ray Adv 3.60.04
          Hardware:
          Intel Core i7-4930K @ 3.40 GHz
          NVIDIA GeForce GTX 780 (4096MB RAM)
          64GB RAM
          DxDiag
            might be double faces too, can try under global settings tab change the Secondary Rays Bias to 0.001
            Cheers,
            -dave
            ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
              I ended up adding a "normal" modifier and having "Flip Normals" checked fixed the issue.
              David Anderson
              Software:
              Windows 10 Pro
              Hardware:
              Puget Systems
              TRX40 EATX
              128GB RAM
