Progressive render noise vs time?
  • #16
    Okay, same issue, but different setup.
    Mac OSX Mojave 10.14.6
    Mac Pro (Late 2013)
    Processor 2.7 Ghz 23-core Intel Xeon E5
    Memory: 64 GB 1866 MHz DDR3
    Maya 2019:
    V-Ray: V-Ray Next for Maya, update 2.1 (v4.30.01 from Jan 21 2020)
    Setup:
    Progressive Render: all default settings
    I have the noise threshold set to 0.0.
    By the information in the pop-up, it says the render will stop if set to 0.0, once either the max subdiv level is reached or the max time limit is reached.
    I set the max time limit to 2 minutes.
    6 minuites later, it is still rendering.
    - Jim
    • #17
      It's hard to say what is going on just by that - can you share some more info like
      - what resolution are you rendering
      - what pass is reached when you see the 0.0 message
      It would probably be easier if you can share your V-Ray log
      Yavor Rubenov
      V-Ray for 3ds Max developer
