Vray RT Benchmark for download
  • Vray RT Benchmark for download
    Vray RT GPU Benchmark
    i created a small BENCHMARK file with 3dsmax and vray RT 3.4 as a production mode.
    all you need to do is to download this file and press the render file
    your GPU card will stop to render when he complete to and hit the 0.01 noise value .
    i know this is not completely unbiased test because he run first Light Cache and then move to pure brute force.
    as you can see i have a old GPU card (750ti) so my test end with 15 minutes to hit the 0.01 noise level.
    so please run this scene and capture you screen to share your render time
    and you gpu card
    THE LINK HERE:
    https://we.tl/TcfCuZ3IVw
    THANKSClick image for larger version
    this is for users with 3dsmax 2014
    https://we.tl/Ak2EqBg1Nh
      This bench mark has no displacement, no transparency, no reflection (okay a little bit)...no HDR... it isn't a very good test.
      I know you were looking for benchmarks....Have you these?
      http://forums.chaosgroup.com/showthr...scal-benchmark
      and this one:
      http://forums.chaosgroup.com/showthr...951-Amd-rx-480
      WerT
      www.dvstudios.com.au
        there is scene you can post here for checking the vray rt?
        any chaos group one?
          as some of you ask... here the same scene but with some materials on them.... hair, glass, car paint and so on... please all of you that take part of the previous test do this test and we see if your gpu is keep on with liner power as cpu or its get slow with the scene get complex.. Thanks!
          here the link
          https://we.tl/NKjMGIYmFK
            12m 03s - Quadro K4200 (single)
            6m 39s - Quadro K4200 (Dual)
            Jez
            3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
            Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
            Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
            ---- Updated 06/09/23 -------
              1m 59s
              3 x GTX980ti
                4m45s Quadro M6000
                Jez
                  3m38s
                  (1x) GTX 980 ti
                  (1x) Quadro K4200
                  4m20s
                  (1x) GTX 980 ti
                  11m 59s
                  (1x) Quadro K4200
                  Dell Precision 7910
                  Xeon E5-2640 @ 2.6 GHz
                  16 GB RAM
                  SSD HD
                  Windows 10
                  Work:
                  Dell Precision T7910, Dual Xeon E5-2640 v4 @ 2.40GHz | 32GB RAM | NVIDIA Quadro P2000 5gb | NVIDIA GeForce GTX 980Ti 6GB | NVIDIA GeForce GTX 1080Ti 11GB
                  V-Ray Benchmark: CPU 00:52 | GPU 00:32
                  Home:
                  AMD Threadripper 1950X 3.4GHz 16-Core | 32GB RAM | (2) NVIDIA GeForce GTX 1080Ti 11GB
                  V-Ray Benchmark: CPU 00:47 | GPU 00:34
                  https://pcpartpicker.com/list/kXKcxG
                    5x 1080 AsusFE DR(2 machines) 58sec
                    It would be faster on one server with 5 gpus but they are busy right now, anyhow scene is too simple to get real impression about GPU vs CPU
                    With scene initialization and all that it was 1m 9s
                    Edit: give it another try(as sequence of 2 frames) here are the results. Faster overall results but it varies in between, probably because of network.
                    1m4s
                      can anyone able to test 1 of the interior of evermotion on 1 card gtx 1080 8 giga
                      or this is not much memory?
                      im sure you have some interiors scene
                      it will be great!
                      thanks
                        (3) Titan XP's
                        1m 8.7s
                        "I have not failed. I've just found 10,000 ways that won't work."
                        Thomas A. Edison
                          Singe GTX 1080 8GB
                          Secound Frame 6:35min
                          Edit:
                          it will be great!
                          thanks
                          Which one? If its free I'll test.
                          I'm in a GPU testing mood today.
                          German guy, sorry for my English.
                            1 minutes and 29 seconds. GTX980ti and GTX1080 Founders Addition.
                            Bobby Parker
                            www.bobby-parker.com
                            e-mail: info@bobby-parker.com
                            phone: 2188206812
                            My current hardware setup:
                            • Ryzen 9 5900x CPU
                            • 128gb Vengeance RGB Pro RAM
                            • NVIDIA GeForce RTX 4090 X2
                            • ​Windows 11 Pro
                            • #15
                              [ATTACH=CONFIG]33217[/ATTACH]
                              that does not look right...wrong view port?
                              Thomas A. Edison
