VrayDirt - Exclude vs Result Affect?
  • VrayDirt - Exclude vs Result Affect?
    Can someone explain me the difference between the options Exclude and Result Affect in the VrayDirt texture?
    Here's what the help pages say about it:
    Exclude – Allows you to disable the calculation of the VRayDirt map for specific objects. Excluded object will not be shaded by the VRayDirt map.
    Result Affect – Specifies a list of objects which will affect the calculation of the VRayDirt map. Excluded objects will be considered "invisible" for the calculations of the VRayDirt map.
    I'm a bit confused as to what's the difference. It sounds pretty much the same to me. I also noticed that Exclude didn't work for me if I wanted to exclude objects from the effect. Only excluding them with Result Affect worked.
    Thanks in advance!
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Everything in the Exclude list won't receive Dirt (and render as if the VRayDirt map wasn't assigned to it, but still generate it on non-excluded objects), while everything in the Result Affect list won't generate Dirt (although still receiving it, when not in the Exclude list as well).
      Thanks, I think this makes it clear now!
      Aleksandar Mitov
      96GB DDR5
