I've rendered walkthrough's many times - and I usually turn to the online help to remind me of the workflow each time - but i'm now confused!!
Read a lot of old / various threads - that just confused me more
https://docs.chaosgroup.com/display/...ough+Animation
What I normally do is
1_set both primary and secondary GI to Lightcache - then renders a 'flythough' lightcache and save it.
2_set the primary GI to Irr Map and the secondary to the saved lightcache
3_render a multiframe incremental irr map (every 10th frame usually)(and save it)
4_I then have a saved irr map and a saved lightcache file
5_I then set primary GI to the saved irr map and secondary GI to the save lightcache map - and render my actual frames of animation.
So - i'm using both files when I render - the online help does not mention a lot of this - but i'm sure it once did - hence why i'm confused?
Am I doing this right? Does the irr map contain the light cache data when it's made after the lightcache calc and save? If so - what do I set a primary and secondary GI?
