Hi Res Render
  • Hi Res Render
    Hey guys, Is there a way to render an image in a higher res than 8000x6000 pixels?
    Vray ROCKS!!!
    it crashes on mine, 8000 is max i think :S
      Is there any way to break down the image and render it in segments?
      This really pisses me off!
      Bt the way.... SKISAME STO PODOSFAIROOO!
      Vray ROCKS!!!
        turn off Rendered Frame Window. THen it should work just fine
        You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
          if you are using max 6 you can use the render stripes.
          Travis
            Thank you guys... I will give it a go!
            Vray ROCKS!!!
              you can also try BIGRender script from Tomas Cayuela Caudevilla
              you can find it on the scriptspot ....
              basically it makes you define the infinite number of regions (or pieces) that you want to divide the scene to .... and then you should only do the composition in PS .....
              Actually, it would not be a bad idea implement that function in the Vray V.1.5 .....
