Denoiser "animation mode" commandline.
  • Denoiser "animation mode" commandline.
    Hello, I've got a quick question regarding the denoiser command line tool.
    I want to denoise an Animation that I've rendered as vrimg files (denoiser Render element was set on "generate elements only").
    Now when I input the vrimg file sequence into the denoiser commandline tool, will it use all the embedded elements correctly for denoising or will it just try to denoise by the RGB channel without any other elements?
    Thanks for the Info!
    -Robert
    Okay, it seems to work well this way sorry for bothering!
    One more question though, when I supply the "-elements=1" parameter, even though I've rendered the full set of elements generated by the denoiser element,
    it's only denoising the RGB and lighting, is this the right behaviour?
    Also,
    is it even possible to render 16bit vrimg files?
    -Robert
      Forget it all!
      I was stupid, sorry for bothering!
