Denoise elements
  • Denoise elements
    As far as I understand, the standard denoiser only does the RGB and NOT the elements.
    Is it possible to use the command line tool to denoise the elements also? (asif they were RGB)?
    Kind Regards,
    Morne
    I've had the same problem recently. As Far as I understand it, you can just use the "-elements" option to denoise all elements separately in order to recompose them, but it does not save the elements as a denoised version.
    You could probably just run the denoiser multiple times and input the render element sequence i.e. "lighting" in order to output just lighting as a denoised version without any further information like "NoiseLevel" or something.
    So if we could get the Denoiser to output the elements as a denoised version as well, that would be fantastic!
    -Robert
      Just adding my support to this request. The reflection elements can get very noisy, in particular.
      http://www.glass-canvas.co.uk
        This is something we are currently working on actively and it will be available at some point.
