HDRI output
  • HDRI output
    Hey guys,
    I'm trying to add a slightly more blue colour cast to a HDRI sky that I've got and using the output curves I'm adding more blue, and taking away a bit of red and green - the result this produces however is a more red/yellow image, almost as if the controls are inverted.
    Is there any reason this should be?
    www.robertslimbrick.com
    I dunno if that's a logical assumption but maybe it has something to do with your camera white balance?
    Software:
    Windows 7 Ultimate x64 SP1
    3ds Max 2016 SP4
    V-Ray Adv 3.60.04
    Hardware:
    64GB RAM
    DxDiag
      I'm keeping the white balance the same during the tests - the only values being changed are the output curves.
        That actually works fine here.
        Would it be possible to attach a sample scene along the HDRI file for investigation?
        Let us also know the versions of V-Ray and 3dsMax you are using.
