V-Ray 3.5 Beta Feedback
  • #16
    Tried adaptive on a scene with lot of lights.
    3.40.03: 52m33sec (probabilistic 16lights)
    3.50.01: 53m (probabilistic 16lights)
    3.50.01: 41m57sec (adaptive: 16lights)
    Changing to adaptive shows lot of extra noise using the same number of lights (that maybe is not correct) ... and some kind of lighting changes that (for me ) is quite interesting.
    NOTICE! Scene is not optimized and low quality gi and so on, just for testing purpose.
    Workstation Core i7 6900 - 32GB RAM - GeF970
    Dual Xeon E5-2630 - 32GB RAM
    • #17
      Both your images are the same.
      A.
      www.digitaltwins.be
      • #18
        Oops.. You're right. Now should be ok.
        • #19
          Quick test in preview quality
          First one is with vray 3.40.03 and phoenixFD 3.00.01: 13m 51.1s
          Second one is with V-Ray 3.55.01 : 10m 30s, but the GI on the scene is darker and noisier.
          Third render: I increased a bit light intensity on scene in phoenixfd fire render settings to get a bit more light on the wall and render time was 11m 25s while still being darker on the wall.
          I tried with adaptive light and render time and result were about the same.
ID:	864340Click image for larger version
          Seems like the GI light attenuate faster in 3.55.
          __________________________________________
          www.strob.net
          Explosion & smoke I did with PhoenixFD
          Little Antman
          See Iron Baby and other of my models on Turbosquid!
          Some RnD involving PhoenixFD
          • #20
            There was a bug in 3.4 that made matte objects receive a lot more GI than they should. Fix of it in 3.5 is probably related to this.
            • #21
              Ok thanks for the info, it's on matte objects yes.
              www.strob.net
              Little Antman
              • #22
                I keep getting the following error with a simple exterior scene using RT:
                "error during initialization stage 9" (or something like that)
                Any ideas?
                • #23
                  Where do I find documentation for 3.5? I have the beta installed but all the help sources I am finding are pointing to 3.4. Basically I want to test and learn how V-Ray works with the Vive via "Live VR Rendering".
                  Can someone point me in the right direction?
                  Thanks!
                  • #24
                    I added point 6
                    • #25
                      IPR
                      - When changing between buckets and progressive and pressing refresh, doesnt change. Idk why would someone wanna do this anyways, but might be useful to interactively change between those 2 modes as anything else
                      - Cant lock viewport in ipr. If i go on other viewports it starts rendering em.
                      - Color mapping changes do not affect ipr.
                      - Region doesnt work?
                      - Changing sampling/gi modes also doent work in ipr. Idk if it should, same as bucket thing.
                      RT GPU
                      - Low priority gpu should be on the fly on and off.
                      - Noise bump bug on vrayplane? (See image) Even if i get noise scale really low, doesnt respond proper.
                      RT CPU
                      - When i add noise at fog density rt stops working. And never opens again until i disable it.
                      ADV
                      - 0.99 reflection gives me wrong shadow reflections (see same image)
                      So far my feedback
                      www.yellimages.com
                      • #26
                        Can you post that scene? It looks like something changed the default settings of your materials... do you use some "optimizer" script or something?
                        • #27
                          No scripts here. I will upload it when i get back to my desktop. thanks
                          www.yellimages.com
                          • #28
                            Thanks!
                            Is it safe for me to assume there isn't any documentation on 3.5? I don't mind continuing without it, just wanted to ask since it would speed up the process of finding everything new. A "yes" or "no" would suffice!
                            Thanks again!
                            UPDATE - Never mind, I figured out the Live VR issue I had. Thanks.
                            • #29
                              We do have a beta docs space which is in progress here:
                              https://docs.chaosgroup.com/display/VRAYMAXBETA
                              It does not contain information for the live VR rendering yet; I made a separate post about it here:
                              http://forums.chaosgroup.com/showthr...t-and-HTC-Vive
                              • #30
                                Hi short cirkuit,
                                I have too seen that same error in the past when using RT. I never did identify the cause and occasionally it comes back. I suspect it is something to do with another plug-in or script, and the use of a custom toolbar button.
                                If you like we can investigate by pm and compare a list of our used plug-ins/scripts?
                                Cheers,
                                John
                                V-Ray 3.40.03
                                3ds Max 2016 SP4
                                Windows 10 Pro
                                2 x GTX 980 Ti
                                5390K / X-99E WS 3.1
                                64GB DDR4
                                Dell UP3216Q
