Proxies question
  • Proxies question
    Hi, I have multiple objects as group that i do not wanna attach as a single one cause i have various animated parts in there.
    How can i export all of em as a proxy without losing the different materials i have? Also after importing the proxies, can i copy em multiple times in order to offset their keyframes? ty
    www.yellimages.com
    If you choose to export the selected objects, at the bottom there is an option to "Create Multi/Sub-Object Mtl" with the current materials, preserving the objects' material IDs. It will be placed in the temporary material library.
    And yes in the VRayProxy options there is an "Offset (frames)" parameter so you can set it for each proxy instance.
    Alexander
    Alexander Kazandzhiev
    V-Ray for 3ds Max developer
      Great Alexander, thanks! so i ll keep this material to a library to re assign it i guess. i ll give it a closer look!
      www.yellimages.com
