Scene Bounding box is too large
  • Scene Bounding box is too large
    Hello all,
    V-ray messages roll-out is warning me: Scene Bounding box is too large, possible raycast errors.
    is this is warning to worry on ? or it is fine to continue? any possible solutions?
    thanks
    PC Specs: CPU i9-14900K - GPU RTX 4090 - RAM 192GB 5200MHz - MB Asus ROG Maximus Dark Hero
    I often have this error and ignore it.
      As maxedesa said - in most cases you can safely ignore the warning, the scene should render fine.
      Miroslav Ivanov
      Chaos Cosmos
        Yes okay, but why is it showing then ?
          I feel lucky when I have scenes where I don't have that . It shows up when you have things too far from origin. Of course when you have big scenes you'll almost always have that. It's showing because the further you go from the origin the less accurate the calculations are.
          A.
          www.digitaltwins.be
            As others told you, you can most of the time ignore this warning and render safely. But even if V-Ray renders fine I would advise you to try and fix this anyway, because 3ds max may behave in strange ways : display glitches, complicated navigation, precision problems, etc.
            mekene
              It's a good indicator that your system units might be too small.
                Yes, you have to change system units to something bigger. It show when you have lets say 1km big scene, but milimetres as system units are used. VRay render this fine I think, but moving in perspective viewport or camera may be problematic.
                AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
                2D | 3D | web | video
                jiri.matys@gmail.com
                https://gumroad.com/jirimatys
                https://www.artstation.com/jiri_matys
                https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
                https://www.instagram.com/jiri.matys_cgi/
                https://www.behance.net/Jiri_Matys
                https://cz.linkedin.com/in/jiří-matys-195a41a0
                  Oh Okay thank you for your replies... but ii want to have accurate calculations even if i am far from the origin? so how to achieve that ?
                    I'm afraid that's not possible. AFAIK double precision calculations has never been implemented in 3ds max. If you really need this you should switch to cinema4d or other packages that support it.
                    mekene
