VrayDistanceTex to change entire object
  • VrayDistanceTex to change entire object
    Hello,
    I would like an 'entire' object to be affected by the VrayDistanceTex.
    What I mean; I'm doing an animation and as objects is getting closer to the one 'master' object, the entire object changes color in one shot. The objects are quite big, so I can see the 'gradient' appearing, generated by the material change of the distance tex. This is not the required effect for this. I'm looking for a solid color change througe the whole object, without gradient
    I could work with animatable materials, but as I have tons of moving objects all approaching at different speed, I would need lots of manual material animation. Wire param also works, but as it is object based, need to do lots of them. VrayDistanceTex could be the way to do this??
    Any ideas?
    Alain Blanchette
    www.pixistudio.com
    You might be able to do this with MCG?
      Probably, I will try that
      Alain Blanchette
      www.pixistudio.com
