Almebic doesnt show in RT
  • Almebic doesnt show in RT
    Hi, is there a workaround for alembic imports within vrayproxy to appear in RT? thanks
    www.yellimages.com
    They should work fine, but you might need to enable rendering of V-Ray proxy files explicitly. Which V-Ray version are you using? We enabled proxies by default in newer builds.
      Hello,
      There is a known bug we need to fix - paths to alembic files are not resolved using Max asset tracker. So only exact paths to the alembic files work.
      Yavor
      Yavor Rubenov
      V-Ray for 3ds Max developer
        I am using 3.20. Is there a fix for this version? What is exact path? And how can i enable this option Vlado? thanks
        www.yellimages.com
          Hello,
          Unfortunately the issue is not fixed.
          About the enable option:
          As for exact paths - I mean that you must set the full file path to the alembic file in the V-Ray proxy. If for example the abc file is D:\Project1\mesh.abc and your scene is also there - you still have to use "D:\Project1\mesh.abc" as a path in the proxy.
          Yavor
          Yavor Rubenov
            thanks.It is working
            www.yellimages.com
              The problem appears again in 3.40.03. The path of the alembic is in our network. Should it be local? thanks
              www.yellimages.com
                Hello,
                Do you see any warning messages in the log - it should print that the proxy file is not found ?
                Yavor
                Yavor Rubenov
                  Heya, no warnings. It just doesnt appear.
                  www.yellimages.com
                    I've tried to reproduce this, but no luck so far. Can you share the scene to support@chaosgroup.com (mention this thread when you do). Thanks.
                    Miroslav Ivanov
                    Chaos Cosmos
                      Will do, I have multiple proxies in there btw, the one is visible the other not. Maybe a clue? ty
                      www.yellimages.com
                        Here u go https://www.dropbox.com/s/l2nn6qq88x...ENDER.zip?dl=0
                        Want me send to support as well? kinda big file sorry almebics are heavy
                        www.yellimages.com
                          That's OK, no need to send it. We'll take a look and post here any findings.
                          Miroslav Ivanov
                          Chaos Cosmos
                            So it looks like an already reported bug where the proxy animation is rendered at the initial frame when "Use alembic offset" is enabled.
                            We'll post here when we get any updates on the issue.
                            Miroslav Ivanov
                            Chaos Cosmos
                            • #15
                              Thanks. Btw in both alembics has the offset enabled and it shows only in the one?
                              www.yellimages.com
