(Authorization) Max 5 to 6 and 1.09n to 1.45.07
  • (Authorization) Max 5 to 6 and 1.09n to 1.45.07
    I am currently running Max 5 with Vray 1.09.03n and I want to test 1.45.07 under Max 6 before I switch both. The I have installed 6 and 1.45.07 for Max 6 and the Auth does not work (as I would expect). Is there a way I can do this? I really need to test this before I switch everything, we have many live projects and I do not want to change without testing both Max 6 and VRay.
    I did not try 1.45.07 for Max 5 since we are moving to 6 (and 7 in a couple months)
    Actually I think the base question is: is it ok to run both on the same box? Vlado?
    "It's the rebels sir....They're here..."
    Check out this thread.
    http://www.chaoticdimension.com/foru...ghlight=#54632
    I think its always a bad idea to swithch platforms and even from Vray 1.09 to 1.45 in the middle of a project.
    If you started in one version I would finish in that version.
    As far as having two versions of Vray on one machine, I followed Fermi's direction from the above post and its worked just fine.
    Bret
