Vray VFB and Vray Zdepth
  • Vray VFB and Vray Zdepth
    Hello,
    Could someone please tell me how to see the Zdepth channel when using the Vray VFB. I can see it in a separate window when using the Max frame buffer but nothing shows up when using the Vray VFB.
    Thanks.....Scott.
    Seems to work fine for me. How are you generating the Z-Depth? By adding the VRayZDepth render element?
      Vlado.......please see attached. Does this answer your question?
        VRayZDepth element like any other V-Ray render element should be visible in the VFB channels dropdown menu here:
        Isn't it there? What about other render elements, are they visible in VFB or not?
          Thanks for the lesson......I forgot to look at the drop down menu...The Zdepth is there. Please forget this conversation ever took place.
          Scott
