Warning: texture map (Normal Bump)
  • Warning: texture map (Normal Bump)
    So, I have learned to ignore these. Converting the scene doesn't help. In Corona, there is a button, which brings you right to the problem texture. In the texture, there is a button to pick, which corrects it for you. Now, couldn't V-Ray automate this process? If there is an error with the normal bump then couldn't the button just get checked, if V-Ray were to have such a button?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    try this in the mean time:
    http://www.scriptspot.com/3ds-max/sc...rt-normal-maps
      That worked. I tried all those before, but not really worked. This one did. Thanks! I am not sure if it makes any difference, but at least I don't have errors
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Yes, I would like that too...for vray scene converter to include normal maps to vray normal maps.
        www.hrvojedesign.com
          Originally posted by Pixelcon View Post
          thanks for the tip mate! Legend!!
          _______________________________________
          behance
          tumblr
          Linkedin
            Converting the scene works for me in V-Ray 3.5. Which V-Ray version are you using?
              I am using 3.5 Beta. It works on some things. i think nested things are the issue.
              https://www.screencast.com/t/q0TZtLAbF
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Please note if the option 'Convert selected nodes only' is selected,
                scene converter works only over selected nodes from the scene.
                Could you try without it and report the result?
                Anna Zaharieva
                  Try the vray scene converter again, but don't check "selected nodes only"? You've got nothing selected, so with that option checked, the converter isn't doing anything...
                    [ATTACH=CONFIG]35834[/ATTACH]
                    Anna Zaharieva
                    Beat me to it...
                      Tried and it took awhile, but it didn't work. I am on another scene. The script posted did work.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
