Any ideas on how to achieve this effect? (foam)
  • Any ideas on how to achieve this effect? (foam)
Name:	Full page photo.jpg
    Sorry that the image is so small
    Thanks!
    Guido.
    The base shape should be fairly easy to sculpt with a sculpting software. The air bubbles you can also do with sculpting with a texture projection brush. Then you can export the sculpted shape without the bubbles and export the finer detail as a displacement map. For the material I would use an SSS material like VrayFastSSS2.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
      Thanks Alex.
      I'll try that. At first I thought this was too much for a displacement map.
      Guido.
        You might get some ideas reading this thread: http://forums.chaosgroup.com/showthr...s-Ratatouille)
        A.
        www.digitaltwins.be
