Vray Frame Buffer IPR - Dynamic Resolution
  • Vray Frame Buffer IPR - Dynamic Resolution
    Hi all
    I have noticed that when doing IPR renders that the VFB will dynamically change its resolution based on the size of the window.
    For me its super annoying and I wish to just render at the resolution I set.
    Thank you.
    There is checkbox inside the render settings that disables this behavior. Not in 3ds at the moment, so I can't tell you where exactly.
    Cheers,
    Oliver
    https://www.artstation.com/mokiki
      Originally posted by stevejjd View Post
      I have noticed that when doing IPR renders that the VFB will dynamically change its resolution based on the size of the window. For me its super annoying and I wish to just render at the resolution I set.
      Go to the System tab of the V-Ray settings and you'll see a rollout named "IPR options". It contains a checkbox to turn this behavior off.
      [EDIT] This option is only present in the 3.50.04 update that's on our website.
        Thanks Vlado !!
