Alpha in a reflection?
  • Alpha in a reflection?
    Anyone know of a nifty way to pull an alpha for a window scenic, but reflected in a mirror?
Name:	Screen Shot 2017-04-07 at 4.23.38 PM.png
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    as long as the shot isn`t too reliant on the reflection could you go old school and just mirror the whole room behind a hollow mirror frame lighting and all ?
    window might not be in the same position so you`d have to tweak that.
    anthonyh
      You could try changing the Affect channels option of your mirror material to "Color+Alpha" or "All channels". This should give you the desired results.
      Nikolay Kusht | chaos.com
      Team Lead, 3D Support | contact us
        Thanks, I'll try that. For the moment, I assigned a color to the window light and then keyed it out in post. Not the best, but it worked for what I was after. I'll try changing channels on the mirror material too. Good thought.
        David Anderson
        Software:
        Windows 10 Pro
        Hardware:
        Puget Systems
        TRX40 EATX
        128GB RAM
