Fake reflections
  • Fake reflections
    I can place a texture inside the vraymaterial environment map to overide the main reflection but would also like the option to not have anything else reflect into the material/object to save on render time. Is this possible ?
    Regards
    Steve
    My Portfolio
    I've just tried using dim distance and set it very low. Would this method reduce render times as it doesn't take into account other objects (or does it still take everything into consideration for reflection calcs) ?
    Regards
    Steve
    My Portfolio
      Wouldn't unticking trace reflections work? Or have I misunderstood.
      Dan Brew
        UNticking trace reflections turns off all reflections including the environmental slot reflections. Basically I need the environment (in the texture slot) to reflect but not any objects.
        Regards
        Steve
        My Portfolio
          trace sets
          Marcin Piotrowski
          youtube
          CGI OCIO config 04
            I just wrote a quick VrayGLSL map for exactly this purpose. But it only works for pure mirrors.
            Code:
            #version 110
            uniform sampler2D Env;
            void main() {
                vec3 normal = (gl_FrontFacing) ? vr_Normal : -vr_Normal;
                vec3 R = reflect(normal, vr_Direction);
                R = (vec4(R,0.0) * vr_CameraToWorld).xyz;
                float y = R.z;
                R.z = R.y;
                R.y = y;
                float m = 2.0 * sqrt(pow(R.x,2.0)+pow(R.y,2.0)+pow((R.z+1.0),2.0));
                float u = (R.x / m) + 0.5;
                float v = (R.y / m) + 0.5;
                vec3 envColor = vec3(texture2D(Env, vec2(u,v)));
                gl_FragColor = vec4(envColor, 1.0);
            If you drop it into a VRayLight mtl it'll give you a mirrored map.
            Gavin Greenwalt
            im.thatoneguy[at]gmail.com || Gavin[at]SFStudios.com
            Straightface Studios
