render time varying heavily!!!
  • render time varying heavily!!!
    i am rendering test files to check out different settings.
    this is not so easy, because render time is varying every
    time i hit the render button
    without ANY changes, i get different render times:
    first try: 1:05 min
    hit render again: 1:35 min
    again: 2:00 min
    again: 1:10 min
    again: 1:45 min
    again: 1:00 min
    what`s going on?
    What version ?
    can you post your file ?
    Natty
    http://www.rendertime.co.uk
      are you using different softwares in background? like messenger, viruskillers, winamp, .... i dont know...what else?
      If yes shutdown every soft when you are doing tests like this. Variations of 30 seconds happends to me either when i does some tests before.
        If you try reset irradiance map, and render again?.
          I remeber reading through the 1.5 help and there is a setting that can make your times change for each render, even if no settings has changed. I started looking again becuase i could not remeber what it was. If you read through the help, the answer might be in there.
          (or it could be something of of these guys/gals said)
          travis
            he don´t wrote he used it at all.
            the effect when reusing the solution should be different anyway.
            that is really strange i think.
