Why is the floor color bleeding only the ceiling?!
  • Why is the floor color bleeding only the ceiling?!
    I'm goin' nuts trying to get a nice and decent ceiling.
    Could someone please give me a hand? I have dead line tomorrow
    here is the scene:
    http://cablemodem.fibertel.com.ar/lupaz/barco.zip
    Very thanks!
    Guido.
    if you are on 1.45.70beta you can just turn down the saturation in the IRR map settings
      TIP ... render the imap with no texture's .... render from the saved imap with texture's applyed ... = no colour bleed
      Natty
      http://www.rendertime.co.uk
        Thanks a lot for answering.
        This image is what I get when I turn off deffuse of the floor material, and then on, useing the saved IRmap.
        Isn't the ceiling too dark compareing it with the walls?
        Thanks.
        Guido.
          try to render everything with a white mat ... save the final imap... ! ... then apply your materials to get a nice white clean job with no colour bleed... try it ..
          Natty
            Sorry! the last image was with Gi for the floor on 0.3! Because I was trying to get color bleeding down.
            This one is with Gi on 1:
            It is much better now! Thanks natty, you 'r a genious!
            Guido.
              Two more questions
              If I turn texture off, the reflections remains ok? or there's a loss or something?
              If I want just a sutil color bleed, the best way to do this is to give the floor a warmish base color or there's a way to control color bleeding?
              I know this last subject is allready on some post, but the post that was exactely what I was looking for had no continuity:
              http://www.chaoticdimension.com/foru...t=dark+ceiling
              Thanks again!
              Guido.
                hey Lupaz can u clear me how did u eliminate color bleeding cuz i have the same problem with a scene...im using vray 1.09...i would really appreciate ur help
                  Sure:
                  -Save the IRmap
                  -on material editor: turn your wood texture off by unchecking deffuse.
                  -render the scene
                  -turn on wood texture
                  -use IRmap from saved file
                  -Render.
                  I was wandering what if I have to animate this!!
                  This is what I get doing that:
                  Guido.
