Noise is coming up in the scene
  • Noise is coming up in the scene
    I am rendering a scene with one vray light and omni light with GI and other with default settings. But the noise is coming up in the scene. Please tell me how to remove the noise from the scene. I am rendering a
    scene at high resolution.
    Hi read this:
    http://www.chaoticdimension.com/foru...ighlight=noise
      After watching the link posting above..... i got the answer that noise will remove by increasing the light subdivisions or samples. But i don't know how to change these. Please tell me under which heading i have to
      increase it.
        Select your light and you will find the subdivisions at bottom of the general parameters. Set it to 20 or 30. That must be fine!
        Cheers
          Mark it depends on the size of the light to how many Subdivs you give it ! so be carefull ... small light's with high subdivs will take a long time to render !
          Natty
          http://www.rendertime.co.uk
            quote="natty":Mark it depends on the size of the light to how many Subdivs you give it ! so be carefull ... small light's with high subdivs will take a long time to render !
            Yes, yes almost forgot about, thanks!
              I don't find out the subdivisions in the general rollout can you post the screenshot.
                select vraylight>modify>parameters>sampling>subdivisions
                All this stuff is on your command panel. (Right side of your display) Customize>Show UI>Show command panel.
                  I found it in the Vray light but the subdivisions not available for the omni and spot lights.
                  And the diffuse subdivs available in the light settings...what are they?
                    Make sure that you have VRayShadows selected.
                    It's in the manual
                    --Jon
                      Jesus Jon .... 1000 x 1000 x 1000 ....that is high ..
                      Natty
                        not for a skyscraper sized window... :P
                          Natty
                            What is the problem with that? That is a 2000x2000 mm window. A normal sized window.
                            • #15
                              Am I wrong???
                              Anyway I don't understand why you changed the Wsize parameter that does nothing
