questions about VRMAP
  • questions about VRMAP
    Can someone explain to me what is VRMAP ? I was see it on my render setting.
    How to create and control a vrmap ? It uses for what case ?
    It's useful for me if you can post some scence with vrmap and without vrmap.
    Thanks so much in advance. Seeing your reply soon.
    "The VRayMap allows you to add VRay reflections and refractions to standard and other 3rd party materials. It's usage is similar to that of the standard Raytrace map in 3dsmax. However, do not use the Raytrace map with VRay. Use the VRayMap instead."
    This is from the Docs.
    http://www.spot3d.com/vray/help/VRay...map_params.htm
      thanks travistlo, it's quite useful for me !!!!!
