RPC crashes max
  • RPC crashes max
    When useing max 6 with rpc trees it keeps haveing a Application Error and crashes max. Any idea as to why this may be happening. The scene only contains 10 or so trees. The final product will have many many trees.
    I need help fast guys. I have already done a search on the forum but know luck. help
    might try posting the vray log.
      try turning off recieve/generate GI for them or"visible to GI" in 1.45 +
      Eric Boer
      Dev
        Macrorecorder needs to be off.
        Call the archvision guys if thats not it, they're generally pretty quick.
        Dave Buchhofer. // Vsaiwrk
          i had problems some like this... was a rpc file corrupted...
          i deleted him and all works fine... find your rpc file wich as caused this and deleted him...
            I got the trees to render buy creating a file with trees in it and then merge the building into the file with the trees. If i open the file with the building in it and put rpc trees in, it crashes. Ok now its not crashing max but when i did a test render this is whats happening now.
            http://www.collinscoopercarusi.com/k...reenGrab-1.jpg
            http://www.collinscoopercarusi.com/k...reenGrab-2.jpg
            http://<a href="http://www.collinsco...y/Test.mov</a>
