Hidden Line
  • Hidden Line
    Can Vray render hidden line or wireframe?
    yeah,
    then new version (beta 1.45) comes with a toon shader that does just that.
    it's pretty simple (nothing like illustrate or finaltoon) but still good for simple hiddenline.
    paul.
      yes to wireframe, use the VRayEdgesTex map http://www.spot3d.com/vray/help/VRay...tex_params.htm
      Eric Boer
      Dev
        Thanks for the help. I have Vray Basic and the only options I have are thickness and hidden edges under the parameters. Is there a way to render a wireframe without the object rendered as a solid - and/or can I render just the edges so it looks like a hidden line drawing?
          You can use it in the opacity slot, and make hidden all the edges you don't want to see
          Eric Boer
          Dev
