OK, I think it is the glossy reflections in 1.46 I'll try 1.09
To All AMD/Intel users....Conclusion...opti wins for now
Rerender...you said something about posting the bench.max file....if you could, that will be great
I rendered the same setup with my other machine using Max 5.1 and the new build and got 10:36
Those are impressive numbers for the opterons! Perhaps I need to take a closer look for my next upgrade.
Rerender, what kind of problem does the latest build have with glossy reflections? Is it just settings or is it something else?
It seems there is a major problem judging by your first render time.
Tony
I should have gotten the 250's they are running at 2.2, and if microsoft release their xp64... plus max version with 64....im glued to AMD.
See you guys...it holiday time for me.
Its the same...Got 2 amd opt here.
Originally posted by TRGraphicsI can't download the file due to security issues. I've never had that problem before.
Reza, what was the machine specs for the max 5.1 machine?
Tony
Reza, What computer renderered it in 10 mins? same exact settings?
I have 2 opteron machine....1 using max 6 and the other max 5.
i copied all the settings from the max 6 file and applied to max 5.1
The tyan motherboard is at default optimum settings....no over clocking.
Original post of this scene (i think it must be said)
http://www.3dsymax.org/foro/viewtopic.php?t=1393
There are a lot of results with this scene in that post
Regards
Originally posted by rezaI should have gotten the 250's they are running at 2.2, and if microsoft release their xp64... plus max version with 64....im glued to AMD.
See you guys...it holiday time for me.Believe it or not I am a big fan of AMD. I'm happy to hear that Opteron is now competative.
I'm still unclear as to which versions of the VRay engine you gents are running. You folks seem to be all over the place.
If this is with the new beta, could the lack of differentiation in the benchmarks indicate that Vlado and company are not yet throwing the compiler optimization switches one way or the other?
According to official AMD doctrine a 1.83 GHz Opteron 244 is supposed to match well against a 3.06 GHz (533) XEON in most generic processing cases.
Very true...i got the file from "indigooo" at his post here "Vray And Dual Opteron Systems" and im using the old 1.09 for max 6 and 1.45 for max 5.1 both on opterons
Sorry...
Ok. Did the test as well.
On a Siemens Celsius Workstation, it took 14:23min.
-2x AMD Opteron 248 / 2.19GHz
-3.25 GB RAM
But I run the normal XP (no 64Bit) and also the normal MAX 6 version.
Btw. I didn't know, that there is a 64bit version of MAX. I thought I supports 64bit in its normal config. Is this an update?
marc
My results:
Time = 14:28.9 using version 1.45.7
Dual Xeon 3.06 533fsb
Asus pc-dl
2gig ram
