Canceling a render?
  • #16
    if i have to guess, then i think it is the same issue as the not working pause button.
    correct me if im wrong.
    but if im not wrong then i read that checking for mouseclicks or keystrokes will slow down vray so much that this feature is disabled.
    maybe it takes so long because vray will only check every 10-15 seconds for a user input?
    at least it´s an idea, when you hear no other comments.
    • #17
      Don't think that's the reason, because you don't have the problem with simple scenes.
      • #18
        was only a idea.
        just now im waiting for 10 minutes that i can use max again because i chanceled a rendering of a scene where i use lightmaps.
        vray just hangs (100% cpu utilization, no viewport update).
        first i saw no progress on the lightmap and now it looks like i have to quit max via the taskmanager. i can repeat this problem with many high poly scenes + displacement.
        • #19
          We need a 'kill' button instead of just 'stop'
          If the problem is the way max stop button behaves, isn't it possible to make a vray-stop button? Something that works like task manager that kills everything inside the process immediately except the process itsself?
          regards,
          wouter
