Updated: Imap Merger Script
  • Updated: Imap Merger Script
    I threw together a little script to automate the merging of Imaps with the Imapviewer. Usage is pretty straightforward. It does require that the latest version imapviewer.exe be located in your Max root and Max 6 or Higher. To install make sure the file extension is still .mzp after download and drag to the Max viewport, after install the script will be available under " customize-Varcht Tools- Imap Merger" as a button. Let me know if you have any problems.
    http://varcht.net/index.php?option=c...d=13&Itemid=28
    Eric Boer
    Dev
    Cool thanks Eric ..
    Natty
    http://www.rendertime.co.uk
      thx RErender , add more infor in http://www.varcht.com/tools.htm plz
        Sorry Max_4_Arch too lazy to do it this weekend, soon though
        Eric Boer
        Dev
          Little update, some computers had trouble finding the Max root.
          http://www.varcht.com/files/ImapMergerMacro.mzp
          Eric Boer
          Dev
            Thanks Eric for the post. Where can I find the Imap-viewer for R5?
            Scott.
              Imapviewer is available on the V-Ray download "documents" area, it is not dependent on Max version, Just My script is. If there was enough demand I could make it work with 5...
              Eric Boer
              Dev
                Got it!....thanks Eric. Funny thing, I never noticed the doc button before.
                Scott.
                  thanks a lot! :P :P
                    I've just tried to combine the single frame irradiance maps that I created last night, and when I load them vray gives me a "file format error" message, and the render comes out all black. I've no idea what I did wrong and how to fix it. Any clues?
                      So this is what has happened so far.
                      Last night I sent a 1500 frame animation to render out across 4 machines, to compute irradiance maps every 20th frame, and saving each irradiance map separately. These were then to be merged in to one irradiance map at the end.
                      I've tried this and it isn't working no matter what way I try it. I try to render it locally and it makes no difference. What I'm now wondering is, if you are to render out a sequence of irradiance maps for every 20 frames, not incremental (becuase I'm using up to 6 computers to render it with) do you have to do it every single frame for the merging to work?
                      When I merge the maps, and render they come out black. If I just use a single irradiance map and render out the frame it corresponds to it looks fine.
                      What is the best way to do this? We have 6 render nodes with 4 cpus in each, and if I want to make an irradiance map using all the available processing power, what do I set it to? I figured that if you used incremental add to current frame it had to be on the one machine, which is why I tried just rendering the irradiance maps as single frames to then merge. I don't know what I've done wrong
                        Hey Eric,
                        now, your script is really cool! Would be even cooler, if the merge of the maps could be sent to backburner as a job aswell, so, as soon as all the GI-files finished to render, one of the slaves would merge them and as soon, as he finished that, all the clients would start the actual rendering of the image...
                        Would save some "get-up"s in the night
                          I'm not usually one to resurrect dead threads, but I just had to say thank you very much for this script.
                          Cheers,
                          Michael
                            cool, glad it is useful
                            Eric Boer
                            Dev
                            • #15
                              Since it has been resurrected, how do i find my max root?
                              pfiles/adesk/max 2008/
                              doesnt work
                              Dusan Bosnjak
                              http://www.dusanbosnjak.com/
