Need help
  • Need help
    i just want to make a white wall, the vray material and light is setting white but when i render it out, it always look orange although the material and light was set purely white color.
    Can someone show me the setting how to make it ?
    Thanks in advance
    Orange ???? ..... is your enviroment Orange or something? post your settings.
    Natty
    http://www.rendertime.co.uk
      Natty,
      sorry for quick answer but i still can not make it white.
      Here is the setting on below
      alll the lights in my scence is white.
        It's colored from the other objects in the room. If you don't want any color bounced from the other objects in the scene you can try out the Ambient Occlusion plugin.
        --Jon
          Hi Jon,
          how can i get this plugin ?
            u can also adjust the color bleeding in the vray mat properties...
            Nuno de Castro
            www.ene-digital.com
            nuno@ene-digital.com
            00351 917593145
              i still can't make it white, can you post the setting ?
                A perfect time to get to know the search feature of this forum
                Just do a search for "Ambient Occlusion" and it should be one of the first topics in the list since it was just recently posted.
                --Jon
                  i think u can work it out without using the ambient oclusion
                  either
                  1 u apply a white varay material to all the opaque objects in ur scene, calculate the irradiance map. attribute the original materials and re-render using tha saved ir map.
                  2 u adjust the gi settings of the wood material so it doesn t bleed too much color
                  Nuno de Castro
                  www.ene-digital.com
                  00351 917593145
                    Which version are you using?
                    In the nwer versions there is a setting for saturation.
                    Under Vray - Indirect Illumination (GI), Postprocessing - adjust the saturation level to prevent color bleeding. Works great!
                    Tony
