I just did a quick test:
standart Max Material with opacity map: 51 sec.
Vray Material with opacity map: 67 sec.
Vray Material with the same map in refraction map slot (ref. index 1): 56 sec.
I did this test on some speedtree scenes too and was a little shocked. A scene with 2 hour rendertime was at 4.5 hours.
Ok, it's a first step. Unfortunatly it's not worth a cent at the moment as it's slower then before. Hope this will get improved.
One hint for using TGA files: Vray interpret the Targa different, so you can't just instance the material from diffuse slot. you have to turn alpha as grey on.
robert
robert
