faked highlights
  • faked highlights
    hmm, seems that i still don´t have a right workaround for faked highlights.
    the hilight glossiness button works good when there is no gi. when you turn on gi the faked glossiness is gone. i just want a normal highlight on round edges without turn on "real" glossy reflections. any ideas ? thanks in advanced...
    Hi Metroberlin,
    Just make a glossy material as normal and then uncheck 'trace reflections' under options. The VRay material then behaves like a standard material. It still doesn't work unless there is a light source to highlight.
    Dan
    Dan Brew
      *bang*..yes, sure..clear....the light..... !!! thanks....
        Why not just use the Highlight glossyness option as it usually tends to be faster than Refl. glossness?
        -dave
        Cheers,
        -dave
        ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
          Dave, can you explain how that works?
          Alexie
            maby a bit later if I get a chance, Im under the gun on a current project...
            -dave
            Cheers,
            -dave
              Thanks Dave.
              Alexie
                If you uncheck 'trace reflections' under options, it doesn't matter if you use Refl. glossiness instead of Hilight glossiness, as they are locked, and when no raytracing is performed, its only the fake hilight being computed.
                Signing out,
                Christian
                  I dont know if the glossy in that way is being used or not thats why I unlock and just use the Highlight glossy
                  -dave
                  Cheers,
                  -dave
