Cartoon skin with SSS
  • Cartoon skin with SSS
    Hi, whats the basic method of blending diffuse+lowerdermal map? I put diffuse in its own slot or in and the other map in scatter color?
    Is Alshader better for this now that has 3 layers + 2 reflections? Also what about phase values for skin?
    Any tips appreciated
    thanks
    www.yellimages.com
    You can try with translucency in a VRaymaterial too. https://forums.chaosgroup.com/forum/...t=translucency
    Alshader look better for realistic skin but it takes longer to render than translucency.
    Look at some test renders I made:
    https://www.youtube.com/watch?v=3AzgGqQ96uo
    render time i got in these tests:
    Alsurface: 28m07s
    SSS2: 28m41s
    skinMtl: 7min6s
    scatterVolume: 30m7s (but full of artifacts and probably more than an hour to get it clean so this one is just too slow)
    V-Ray translucency in standard V-RayMtl: 4m50s
    __________________________________________
    www.strob.net
    Explosion & smoke I did with PhoenixFD
    Little Antman
    See Iron Baby and other of my models on Turbosquid!
    Some RnD involving PhoenixFD
      Thanks, informative stuff there. Well i ended up using alshader with only 1 texture and seems to work good. Cant share nothing though for now, but i d like some tips for improving it. I agree with u in the video, i find it very hard to control vray SSS in general and same goes for transulcency.
      To alshader thing: if i use only 1 texture for diffuse, and put sss mix to 1.0 im good? Thats basically my setup and seems to work ok. I added a vrayblend mtl with another alshader reddish color to control more the nose and ears. Would that be ur approach? thanks a lot
      www.yellimages.com
        While this works, it will slow down your render. It would be more efficient to use just one material, but use different textures to control the scatter radii and/or colors.
          Thanks for the tip Vlado. But how i boost the SSS amount if i wanna exaggerate it and double lets say the amount in the ears? Use a b/w map in sss mix so some parts dont have sss at all?
          www.yellimages.com
            You would play with a map in the refraction and fog color along with the fog multiplier as well as the backside color map and the light multiplier under it.
            By the way I am playing with this right now but I used a blend material with a mask and I pumped up the ligth multiplier and fog color to add more light in the sss. And I am getting red dots artifacts.(they are in the refraction pass) when using brute force + light cache. If I use brute force + brute force the dots disapear.
            I will try to put my mask in the fog color instead of a the blend material blend amount.
            www.strob.net
            Little Antman
              So I put my mask in the refraction instead of the blend amount af a vrayBlendMaterial an dyes it renders a lot faster and I don't get those red dots anymore that way.
              www.strob.net
              Little Antman
                Can u share a scene with this setup? Just curious to see how this works.
                Thanks
                www.yellimages.com
