Adding multiple normal maps
  • Adding multiple normal maps
    Hi, how can i add multiple normal maps? I got 1 from zbrush and 1 from substance painter and i wanna use both. Thanks
    www.yellimages.com
    I know i should probably bake the high poly normals to the low poly model in substance and continue from there, but i dont have the zbrush mesh. So so far i used a vray normal map, i added the one map in the normal slot and in the 2nd slot i added a color to bump and added the second map. Is that proper? ty
    www.yellimages.com
      Rens made a great osl for that:
      http://www.rensheeren.com/
      You could also use nested VRayBumpMtl materials I think.
      German guy, sorry for my English.
        Thank u very much. Does this work in latest vray? I d prefer not to use plugin for this and maybe nested method with some proper filtering or something. Thanks again
        www.yellimages.com
          Yes I think it works in any vray version with osl support. (which was a few versions ago.. I dont know, Its been around for a while)
          A great thing about osl's is that they're handled like textures.
          So you just need to make sure all your nodes have access to the osl and you're ready to go.
          No installation and stuff. Distributed rendering even spreads them on its own. Just like textures
            mix sub map
            Archviz Designer. 2x 2990wx + 4x 1950x + 3x 1800x / Nvidia RTX GPU.
            3dsmax / maya / vray / corona / redshift / unreal / fstorm / arnold
              Awesome!! didnt know that! thanks
              www.yellimages.com
