Hi, is that possible? Dont wanna bake it onto beauty. thanks
Aerial perspective only as element
Tags: None
Originally posted by mohammadreza_mohseni View Postyou can get your beauty pass usual way. and then turn off GI and lights (through the global switch) then make a black material and apply to override and then apply your aerial perspective and render it separately really quick
Originally posted by savage309 View PostNo I mean, if you substract the amtospheric from the rgb, you should get the "rgb without atmospherics".i ll do a test render. Thank u all for ur time!
Update:
Subtracting the fog element in 32bit project in AE(srgb, linearize on), didnt do the trick. Gave me another image a bit different than the beauty, close but darker. Didnt try aerial perspective yet, but i guess i will have similar issue. I shouldnt though right? Math is math and compositing with adding and subtracting should work proper.
Maybe in nuke is a different story?
