VRay Proxy between Max and Rhino
  • VRay Proxy between Max and Rhino
    Hi, I have a question about the workflow to work bretween Rhino and Max, in our company we model everything in Rhino and render with Vray, and most of the times we have to export to Max or Maya for animations, I did some tests about vray proxies but can?t find a way to export also the materials and uv mapping seems not being there. Is this actually possible? aren?t the materials between applications compatible? also checked the vray scene export, but them I can?t change the materials in max if i have to. Which would be the most efficient workflow ?
    Thanks in advance.
    We will greatly appreciate if you place reference links when you open multiple threads for the same thing in different forum-sections.
    Please check my response in the other thread you've opened:
    https://forums.chaosgroup.com/forum/...-max-and-rhino
