select all objects with incompatible materials?
  • select all objects with incompatible materials?
    does such a script exist? i cant find anything on scriptspot.
    Had same issue, KStudio path was suggested, didnt try it yet (has some options like selecting by name etc.) but what actually solved everything is Vrayscene converter without bothering with those mats anymore
    www.yellimages.com
      these are octane materials, there isnt any kind of converter that ive found.. id love it if vray scene converter was a bit more full-featured. it would make collaborating with an octane user a damn sight easier!
        I use this:
        Code:
            local allSceneMats
            fn matSortFN mat1 mat2 =
                case of
                    (mat1.name < mat2.name):-1
                    (mat1.name > mat2.name):1
                    default:0
            fn getSceneMats =
                local sceneMats = #()
                for c in material.classes where c.creatable == true do
                    mats = getClassInstances c
                    join sceneMats mats
                qsort sceneMats matSortFN
                sceneMats
            fn analyseScene =
                clearListener()
                allSceneMats = getSceneMats()
                for om in allSceneMats where (not (areMtlAndRendererCompatible om renderer:(vray())) or (isKindOf om architectural)) do format "% - % %\n" (classOf om) om.name (refs.dependentNodes om)
            analyseScene()
        It prints to the listener the names of any materials that aren't compatible with V-Ray and lists the names of any objects that they are applied to. It could be adapted to select the objects instead very easily.
        Dan Brew
          If u make this script select em as well, u rock
          www.yellimages.com
            agreed
            ive got no scriptin' so it would be a big favour.
              Ok, here's an updated script that selects all objects that have incompatible materials.
              Code:
                  clearSelection()
                  clearListener()
                      case of
                          default:0
                  fn getSceneMats =
                      for c in material.classes where c.creatable do
                          join sceneMats mats
                      sceneMats
                  fn analyseScene =
                      local objs = #()
                      for om in getSceneMats() where (not (areMtlAndRendererCompatible om renderer:(vray())) or (isKindOf om architectural)) do
                          local nodes = refs.dependentNodes om
                          format "% - % %\n" (classOf om) om.name nodes
                          for n in nodes do appendIfUnique objs n
                      select objs
                  analyseScene()
              It's a bit difficult to test as I don't have Octane installed so let me know if it doesn't work.
              Dan Brew
                thanks!
                if i wanted to give this to my colleague, who uses Octane.. is there a way to make it renderer agnostic (i.e. it will select objects with materials that are incompatible with *whatever* the current renderer is?) or would that involve code specific to each renderer?
                  Originally posted by super gnu View Post
                  thanks!
                  No it's quite straightforward...
                  Code:
                      clearSelection()
                      clearListener()
                          case of
                              default:0
                      fn getSceneMats =
                              join sceneMats mats
                          sceneMats
                      fn analyseScene =
                          local objs = #()
                          for om in getSceneMats() where not areMtlAndRendererCompatible om renderer:renderers.current do
                          select objs
                      analyseScene()
                  Dan Brew
                    Ur awesome mate! thanks a lot
                    www.yellimages.com
                      Thanks for this script DanielBrew, so helpful!
                        nice one guys... thanks!
