How to set dynamic memory limit in vray RT CPU
  • How to set dynamic memory limit in vray RT CPU
    Hi all
    I'm using rt CPU to bake some displaced textures. However it keeps, not crashing, but just hanging, similar to if I have dynamic memory limit too low in regular vray. However, I can't seem to find any settings to change the memory allowance in vray rt CPU. Any advice or help would be much appreciated.
    Many thanks
    Will
    You can check/change it with
    Code:
    renderers.current.V_Ray_settings.system_raycaster_memLimit
    Peter Matanov
    Chaos
      EDIT: Figured it out,, its
      renderers.current.V_Ray_settings.system_raycaster_ memLimit = 40000​​​​​​​​​​​​​​ ​​​​​​​many thanks again!
      Firstly thank you for such a quick and correct response. Its really appreciated!
      I'm a bit of a noob when it comes to max script. I've put that command into the listener and get returned 4000 so my suspicion was correct and the memory is set very low. What exactly do I type to set it to either "0" or 40000" as I'm trying a few options and just keep getting errors so I assume my syntax is wrong?
      Many thanks again.
      Will
        Code:
         renderers.current.V_Ray_settings.system_raycaster_memLimit = 0
        where "0" is a special value which makes V-Ray to determine the amount automatically. If you want to input something else - then type the desired number after the "=".
        Peter Matanov
        Chaos
