Hello! I'm buying a new system and I would really appreciate some info so I can decide which way to go. I can either get dual Xeons with a lot of threads and lower GHz or a dual Xeon with a lower amount of threads and higher GHz (which is a cheaper processor). More threads is great for CPU render and higher GHz is great for GPU render from what I heard.
I'm doing some huge environments on the project I''m working on (which is reaching around 600 million polys- with all XRefs around 6GB file with quite of bit of textures) and I know that Vray CPU will render it but I'm not sure if vray GPU can handle that much data. If I go with a cheaper and higher GHz Xeon, I can put 4 Titan Xp's, otherwise I will have 4 1080Ti's (with the more threads Xeon). So to resume:
Dual Xeon E5 2697A v4+Four 1080Ti= More threads and geared towards CPU, but able to do good GPU render
Dual Xeon E5 2643 v4+ Four Titan Xp= More GHz and geared towards GPU render. Not a good choice for heavy CPU renders due to a low amount of Cores/Threads
A more technical comparison between the processors:
http://www.cpu-world.com/Compare/487...-2697A_v4.html
I tried to find documentation online about it but with no success. Do you guys have any insights in this matter?
Thanks so much!!!!
-Fausto.
