Gpu vs cpu
  • Gpu vs cpu
    What should I expect to be faster for stills? 36-Core Dual E5-2696 v3 Max 3.8GHz 128GB RAM or EVGA GeForce GTX 1080Ti 11GB
    I ask because I ran RT, using the GPU and it was slower than rendering using progressive in the CPU. I also ran RT in hybrid mode and that was also slower, which didn't make much sense.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Are you sure you are rendering for the same noise levels?
    Best,
    Blago.
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
      Best,
      Blago.
      I am just using the defaults, so I'll have to check. It sounds like RT should be faster and RT with GPU/CPU should be fastest, correct?
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Would definitely be interested in the results because that's a massive price difference between the two
        e: info@adriandenne.com
        w: www.adriandenne.com
          The image sampler behaves differently in RT/Adv. The easiest way is to compare the renders after the same amount of time. Also, make sure to use V-Ray GPU as a production render, since it's ray bundle size / rays per pixel / etc settings there are optimized for final frame rendering.
          Best,
          Blago.
          V-Ray fan.
          RTX ON
            I believe (correct me if I'm wrong) that GPU's typical excel at calculating direct lighting. So your interior scenes which rely on indirect lighting (GI) would require more than a single GPU to match the performance of your CPU. Plus not having to think about memory constraints on your GPU vs CPU is something to consider.
              This is not quite the case. This is more what like the results should look like.
              Best,
              Blago.
              V-Ray fan.
              RTX ON
                Okay, good to know, Thank you!
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Best,
                  Blago.
                  I'll read earlier. Are there any setting I should tweak to improve GPU render times?
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Ideally it should work out of the box.
                    Best,
                    Blago.
                    V-Ray fan.
                    RTX ON
                      I'm curious how this ends up. I've got the some type of results but my machine isn't pimped out like Bobby's is. The CPU's win every time in my tests, but every article I read tells me this is impossible. I'm doing something wrong but I don't know what...
                        Hybrid has to be faster if it is using both the CPUs and the GPU's. My current interior is using 19MB or RAM and I have a 11MB vcard, so I am assuming everything can't fit on the card. Unless it's not apple and apples when it comes to CPU and GPU RAM. Regardless, in hybrid mode shouldn't it fill the vcard and rest renders on the RAM?
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          After reading the below article, there should be no reason why GPU+CPU wouldn't be faster than anything else. In my case, it isn't the case, so I am confused.
                          https://labs.chaosgroup.com/index.ph...rid-rendering/
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            As I said, if you are not testing rendering for the same time + comparing noise after that (and the same settings, for example BF+BF), your test might not be accurate.
                            Best,
                            Blago.
                            V-Ray fan.
                            RTX ON
                            • #15
                              I've run into an issue before where RT was rendering very slowly (in production mode). Usually, this goes away when stopping and restarting the render.
                              Check my blog
