Fog
  • Fog
    I can't seem to get my fog right. I am not sure if fog or haze is the same, but I just want my scene to get a little fuzzy the further you go from the camera. How do I do this? I don't like the white-out horizon line I get with anything I try. I set the height to cover my scene and the distance pretty far out.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    You should try vrayaerialperspective instead. You will need vray sun to get it to work.
      Okay, I?ll give it a try, thanks!
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Pro Tip. Set your Sun to Include with no elements affected. You can light your scene with an HDRI and have only the vray sun generating the effect.
          I will try that, thank you!
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Okay, I have no clue what you mean. How to you set your sun to include with no elements effected? I added a volume fog and I am not seeing any of those options. I added the sun, but that is as far as I can get.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              EIther is supported in the Progressive render, correct?
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                For aerialperspective to work you will need vraysun in your scene, but sometimes its not desired as you might want to use only hdri as your lighting. In that case you can add sun, select it and click exclude under vraysun parameters. Standard its on exclude and no objects selected (so it includes all objects in your scene), but if you switch it to include and don't add any objects there, it will not affect anything except aerialperspective. It will not create lights/shadows, but you can change its position to control the overall look of your fog/haze effect.
                  The boundary blog has a good tutorial for vrayenvironmentfog.
