Any way to apply a gradient map to a vray displaced piece of geometry??
  • Any way to apply a gradient map to a vray displaced piece of geometry??
    Because vray displacement is carried out at render time it seems impossible to apply a gradient ramp to it as a mix map mixer channel to mix between 2 different textures at different heights. Is this not possible ? Applying a UVW map doesn't seem to work either.
    Regards
    Steve
    My Portfolio
    You should be able to do that.
    Tashko Zashev | chaos.com
      Somwhat related. Ive been playing with vraydisplacement within a falloff map to minimise the calculation at distance and noticed that it only worked with 3d displacement. 2d would ignore the falloff. Is this correct or a bug?
        2D displacement need mapping coordinates to work. For maps designed to work in object or world space (Falloff for an example) you have to use the 3D mode.
          Steve, what sort of map are you using to displace?
          You could control your blend with the same map in an output map.
          If you colour remap, match your desired gradient represented below the graph.
          Gavin Jeoffreys
          Freelance 3D Generalist
            The only way I've managed to do this so far is to just treat the plane as a 2d map so I have to use a radial gradient or circular texture to act as an alpha. If I try to use a UVW map for the channel I think it just assumes it is a plane and cannot calculate the UVW mapping at render time. I'll check out the above posts as I've not had a chance to try them yet. Cheers
            Regards
            Steve
            My Portfolio
