Intel machines render PhoenixFDOceanTex vector displacement differently than AMD machines
  • Intel machines render PhoenixFDOceanTex vector displacement differently than AMD machines
    I've got a scene where I use PhoenixFDOceanTex as a vector displacement map to create waves in an ocean. If I render the image only with the AMD machines (Threadripper 1950X), the ocean renders fine. If I render only with the Intel machines, it also renders fine. If I render with both AMD and Intel, however, I get messed up patchy ocean surface because they render the vector displacement differently. I did some tests with regular displacement (using bitmap textures) and it renders fine with a combination of AMD and Intel machines so it seams that only PhoenixFDOceanTex causes this problem. Let me know if you need a scene and I'll send one but I think it should be pretty easy to test - just make a plane and add a vector displacement to it with the PhoenixFDOceanTex map.
    Please check the screenshot below.
    EDIT: Sorry, I just saw that I posted the thread in the "General" section. Please move it to the "Problems" section if necessary.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Hello,
    Can you send the scene to support@chaosgroup.com so we can check it out?
    I couldn't reproduce it in here with the latest official release build. What build are you using?
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Hello Georgi,
      I'm using Vray 3.60.01 on all machines and the Phoenix2.dlr plugin + vray_phoenix.dll.
      I've just sent the scene to the support email. Thanks for looking into it.
      Aleksandar Mitov
      96GB DDR5
