Urgent! Mesh lights/VrayLight materials not casting light
  • Urgent! Mesh lights/VrayLight materials not casting light
    I've got a very urgent issue with a rendering that I have to deliver very soon. I've got furniture which I need to add LED strips to (in the plinth) and the only way to do it is by using mesh light or VrayLight material because the furniture is curvy/irregular shape so I can't use regular rectangular plane lights. The problem is that VrayLight material and Mesh lights cast almost no light even with very high intensities. Not only this but they render EXTREMELY noisy even when left to render for a very long time compared to regular plane lights which clear up in seconds. How can I make it work?
    All Vray settings are at default and the normals are not flipped. Vray version is in the signature. Please check the image below. I'm about to hit the deadline so any help is appreciated.
    Edit: I've scene the scene to support.
    Click image for larger version  Name:	mesh_light_problem.jpg Views:	1 Size:	130.1 KB ID:	973218
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Hello,
    Did you check the mesh normals ?
    Also, since you don't precise it, I guess you're using VRay Adv and not RT ?
    Nicolas Caplat
    www.intangibles.fr
      Normals are not flipped. I'm using Adv.
      Aleksandar Mitov
      96GB DDR5
        Hmmm crap ... I'm afraid I don't have more ideas
        Nicolas Caplat
        www.intangibles.fr
          Have you tried with adaptive lighting turned off? Not sure if it could be the issue.
          Gavin Jeoffreys
          Freelance 3D Generalist
            Good idea, Raven.
            Best would be to share a stripped down version of scene, so that others could test ...
            Nicolas Caplat
            www.intangibles.fr
              Tried, no change. I might just render this light on a separate pass, crank up the multiplier to something like a 1000, use denoiser and deal with it in post.
              Aleksandar Mitov
              96GB DDR5
                OK, the essential is that you found a workaround, thus allowing you to deliver. However, I'd be curious to get CG guys feedback for this kind of problem.
                Maybe worth checking if updating to the latest VRay version solves your problem.
                Nicolas Caplat
                www.intangibles.fr
                  Can you save just the mesh light out, would like to take a look, as I have not come across a problem like this before.
                  To me, it must have something specific to do with this geometry.
                  Gavin Jeoffreys
                    Scene attached.
                    Aleksandar Mitov
                    96GB DDR5
                      It looks like it has to do with face normal directions.
                      Take a look at the image. On your light, the bottom-most faces of you light are not pointing straight down.
                      I did a test recreating it from the spline of the chair base and adjusted the angle on the spline render settings so faces are pointing directly down.
                      Gavin Jeoffreys
                        Thanks for taking the time to troubleshoot it, Raven. I think this might be it! Really appreciated. It is indeed a lot better, I didn't even consider that the shape being round would affect the casting of light downwards. It's still really slow and noisy though even when left to render for a while. Maybe this is the nature of mesh lights?
                        Aleksandar Mitov
                        96GB DDR5
                          I have to use mesh lights a lot on car interiors for ambient lighting. It is not much slower then a regular light.
